Adler
5 February 2006 | 01:44
В звуковых файлах арканума есть примерно такой вариант концовки: «Вернувшись в Арканум вы стали добрым ( злым\нейтральным) богом…..»
Так вот, как это сделать, кто-нибудь, что-нибудь знает об этом?
melkor
5 February 2006 | 22:13
ВНИМАНИЕ! Далее следует занудное игроковырятельство, просто кишащее спойлерами. И оно так до конца не отвечает на поставленный вопрос: данные непроверены. Я предупредил ;-).
В игре есть не только выбор "добрый-злой-нейтральный-бог". Концовок, касающихся судьбы протагониста несколько, и все они похожи по своему принципу:
(извините за возможные неточности, но записывать со слов того слайдово-финального дядечки очень тяжело)
V32 m Upon returning to Arcanum you assumed a rule of death champion, laying waste to cities and villages all across the land. Your lust for death and destruction was insatiable and millions died before you decided to stop. Scattered groups still survived in the existing wastelands, but Arcanum never recovered from the cataclysm caused by your hand.
V33 m Upon returning to Arcanum you are revealed as a hero and many legends were told about your adventures and your final battle with Kerghan the Terrible. As years went by, your name became almost mythical, spoken on the same breath as the heroes' of old.
V34 m Upon returning you assumed a rule of a just god and all of Arcanum revealed your benevolence and wisdom. All grudges between the races were forgotten and the new code of honor and morality was adopted by all. Your reign ????? in the golden age where both magic and technology were accepted and used to build a better world.
V35 m Upon returning you assumed a rule of a dark god. With arcane forms of worship and sacrifice Arcanum became a place of pain and shadow where men were afraid to speak their minds or follow their dreams. The world you made was a hard place. By the few those who survived you were worshiped but you were also hated and feared.
V36 m Upon returning you assumed a rule of a quite god and slowly faded into memory. Arcanum continued to prosper and many legends were told about your battle with Kerghan and defense of the world. Using your life and your ventures as an example races of Arcanum entered into the new and enlightened age devoid of fear or darkness.
V37 m Upon returning you wandered Arcanum for many years indecisive to exactly the kind of god that you wish to be. You lived among many peoples speaking with them and learning the hearts and minds. The world waited expectantly for your words and your wisdom, and waited a long, long time. |
Вот такие концовки.
Они должны активироваться вот этими глобальными флагами:
{2050}{cmoore - 1 The PC has told Kerghan that he will be Death's only champion} {2051}{cmoore - 1 The PC has told Kerghan that he is walking the path of the righteous} {2052}{cmoore - 1 The PC has told Kerghan that he will be Arcanum's only god...a just god} {2053}{cmoore - 1 The PC has told Kerghan that he will be Arcanum's only god...a dark god} {2054}{cmoore - 1 The PC has told Kerghan that he will be Arcanum's only god...a quiet god} {2055}{cmoore - 1 The PC has told Kerghan that he will be Arcanum's only god, but that he doesn't know what kind of god.} |
В скрипте, управляющим финальными слайдами эти флаги используются, и, насколько я могу понять, используются правильно.
Итак. Как включать? Ковырянием скрипта и диалога Кергана выяснено, что после того, как игрок согласился присоединиться к Кергану и прибил Арронакса, Горгота, Бейна из Кри и Крака-Тура, должен состояться приблизительно такой диалог:
Kerghan: Splendid. Then you are truly ready to walk by my side on this journey. It is only for us to cross the bridge...are you ready? Player: I don't think so. I believe I've changed my mind... Kerghan: [Kerghan squares himself to you, his fists clenching; you can feel the immense power that he commands.] I've no more time for your games, traveler. You must choose, and now. Do you walk with me, and with death? Or do I send you to that great, dead sea right now...? |
После чего у игрока появляются замечательные варианты ответа:
I will walk with death. I will be his champion ALONE... I still have the choice, and I choose the path of the righteous... Neither you nor death will be god. I alone will rule as I see fit. |
Собственно, все они ведут к «необычным» и даже «божественным» концовкам.
Осталась самая малость. Проверить ;-)
Или же найти человека, который эти сами концовки включал.
Merlin
12 February 2006 | 17:35
К счастью, у меня был сэйв перед самым разговором с Керганом, так что сейчас я всё быстренько проверил.
Так вот, данные варианты диалога в игре действительно есть! Причем для их появления вовсе не обязательно убивать Арронакса со товарищи - вариант "I believe I've changed my mind" появляется сразу же после первоначального согласия с планами Кергана.
Но! Если пойти по этому пути после убийства Арронакса с остальной четверкой, более того, если даже просто согласиться это сделать (а потом "передумать") - в финальной заставке (после боя с Керганом) реализуется стандартный вариант "смерть всему живому".
Если же "передумать" сразу же после первоначального согласия - то не будет вообще никакой финальной заставки. Что-то быстро мелькает - и все, игра выходит в главное меню.
Так что - увы, не быть нам богами. ;) А жаль...
P.S. Да, кстати, - вариантов ответов там даже больше. Для одного выбора типа бога ;) есть целая подветка, а ведь можно вернуться и просто героем...
melkor
12 February 2006 | 20:49
Понял.
Значит так. Сначала игра проверяет, присоединились ли мы к Кергану. Если присоединились - все, Арканума больше нет. Если не присоединились - смотрим слайды дальше.
Проблема в том, что на божественные концовки можно выйти только через согласие с Керганом. За что получаем gf2632 - присоединились к Кергану. Но если мы вдруг передумали, то флаг не снимается! Игра продолжает считать, что персонаж заодно с Керганом!
Отсюда и соответствующие концовки.
Немного поправив диалог с Керганом, можно сделать так, чтобы при отказе злополучный флаг сбрасывался.
Вот здесь можно взять правленый диалог, положить его в папку data/dlg/ (если нет - создать).
Merlin, проверь, пожалуйста, концовки с внесенными изменениями, если не лень, конечно =)
Merlin
12 February 2006 | 22:30
(потирая ручонки) Хе-хе, всё получилось! :) Правда - после некоторых дополнительных телодвижений.
Сначала, когда я запустил игру с твоим патчем, меня ждало небольшое разочарование: даже при скорейшем отказе больше ничего не мелькало, а тоже шла "плохая" концовка.
Несколько расстроившись, я решил попробовать еще раз - но выбрать путь не бога, а просто героя. А вот тут оказалось всё в порядке - изменения сработали. Причем новая заставка была очень красивой - прямо хоть выдирай из игры и помещай в качестве обоев на рабочий стол.
Я открыл твой файл в редакторе и немного над ним помедитировал. Оказалось, у каждого варианта концовки есть свой идивидуальный "сброс" флага: "gf2632 0". Но ни у "божественной" ветки в целом, ни у конкретного варианта выбора "типа" бога такого сброса, увы, не было. Я быстренько прописал его, и снова попробовал...
И на этот раз "моторчик" затарахтел! :)
Я могу выложить окончательный(?) вариант файла, но, думаю, будет правильней, если это сделаешь ты - первооткрыватель. :)
Все же остальные записывайтесь в очередь - "порулить" Арканумом. Who wants to be a God? ;)
melkor
12 February 2006 | 23:39
Ага, немного топорно вышло. На скорую руку правил, не подумал о еще одной ветке.
Выкладывай сам, какая разница =)
P.S. Да, этот случай еще раз показывает, сколько Арканума потеряно из-за мелких ошибок...
Merlin
13 February 2006 | 00:21
"Эт' точно" (с) товарищ Сухов
P.S. Выложил:
ссылка
Adler
16 February 2006 | 10:54
Как здорово, что унас есть такие умельцы! А то я что, только ни делал, что бы добиться божественной концовки. Ведь я сначала полагал, что для этого нужно пройти три божественных круга и принести жертву Вилориену, но естественно обломался. Потом я попытался выполнить все квесты, для положительного будущего для городов (ну там, вернуть максимилиана, зачистить бойл и т.д.) это естественно тоже не помогло. Потом, я думал, что надо достичь максимальных характеристик персонажа, для этого я использовал тренер, но и это не помогло, а всё дело было в «пустоше»!
Кстати я думаю, что было бы лучше, если божественная/героическая концовка, зависела бы от стиля прохождения игры. Ну, там стать богом, если пройдёшь три круга богов, героем, если выполнишь, положительные квесты и т.д.
Ладно, спасибо за помощь и заплаты для игры!
melkor
16 February 2006 | 16:34
>>Ну, там стать богом, если пройдёшь три круга боговМожет быть, станешь богом. Или же
бог станет тобой? ;-)
