Я ни в чем не уверен, но просматривая от нечего делать FT Tools.exe нашел такой блок:
.?AVWSpriteEditor@@ Reset Position z: y: x: Bounding Box TC1 Hair Skin Base Segment Colors Step Size Sequences Animations Release Loop Extents BBox Grid Stop Slow Play Frames Rotation Current Seq: Current Anim: /f:/graphics/animations/_renders/.cfg /f:/graphics/animations/_renders/.png /f:/unfinished sprites/.spr Sprite Editor Could not open File! Open a sprite file Could not save File! Dir of Single frame sprites Rename Animation Delete Unused Animations Delete Animation Replace Animation Import Sprite Cfg Import Single Frame Import Animation Insert Key Frame Check Sequence Names Add Dodge Sequences Sort Sequences Find Sequence Rename Sequence Add to Sequence Edit Sequence Delete Sequence Add Sequence Import a sprite config Modified glass plastic carpet ethereal rubber water swamp mud rock gravel dirt plant_soft plant_hard grass ceramics metal_thin brick concrete metal_thick Failed to parse material, using metal_thick material Failed to parse foot position, aborting load Point foot_position Failed to parse bounding box, aborting load C:preunidevbosspritewsprite.cpp Integer3 bounding_box_size failed load error saving a file error loading a config error loading a file user cancelled load sprites Warning %s exists, overwrite? No to All No Yes to All Yes spr _BASE_0_0000 png Loading Directory cfg Import an animation You must have an animation selected to replace Replace Animation? Are you sure? Replace an animation could break sequences that use this animation. Import an directory Rename Animation? Delete Animation? Are you sure? Deleting an animation will delete sprite sequences that use this animation. Delete Unused Animations? You must have at least one animation selected
to make a sequence Sequence already exists! Sequence Name Are you sure? Delete Sequence? Rename Sequence? Could not find animation One Two Dodge Could not find sequence: %s forward back Getup UnknownNames
Missing Names
Special Key Pickup Start Overlay Anim Rate Anim Delay Anim Goto Anim Repeat Weapon Release Weapon Fire Sound start Right Footstep Left Footstep , Type in Release Point Type in Special Key List Type in frame to jump to Type in ms to delay Type in ms rate for animation to play Enter Sequence %s: %d/%d
IMHO, все это относится именно к пропавшему редактору спрайтов!
Take My Revolution
